4 hours ago, Yetti said:
I am not saying that MMO will help you make a stuck valve get to annual, but if you think about it the engine design and MMO are of the same vintage.
MMO dates back to 1923 as a carburetor cleaner/flush.   Word is that radial engine maintenance outfits in WWII got it by the barrel, and used it up regularly.   It's been a regular component in aviation maintenance for nearly 100 years.   Not even remotely a new or untested thing.  ;)
How would one know…
The oil ring is a bit gummy?
Then…
How would one know…
The oil ring has been cleaned?
Sounds like…
Oil may be showing up in the lower spark plug?
A sign that the oil ring isn’t doing its job…
could be a cylinder surface quality issue as well…
If sending a camera down the cylinder is possible…
be on the lookout for polished surfaces where they used to be cross hatchings.
+1 for selecting a solvent mix that is good at dissolving carbon…
PP questions only, not a mechanic…
