I've heard mentions before about adjusting the stall warning assembly. If one wanted to have the stall horn activate at a lower airspeed, would that require loosening the inner screws and then moving it up a bit?
4 hours ago, 1980Mooney said:
Yes but you really need to read the Service Manual - Chapter 27 -Page 16 and 17.
You do have the Service Manual, don't you?
I do now. Thanks for the reference, that’s what I needed.
my stall vane was so far out of alignment that Brian Kendrick had to drill out at least two of the four rivnuts to be able to move it to the right spot
