Anyone know how to look up the specifications for this Heim joint on a 1989 252?  Apparently Mooney felt it was important to specify that the bolt that goes through it (10) is an AN3-11, but no reference to the Heim Joint.
Looks like it might be a standard Heim joint with a male threaded end.  Lasar stocks a wide assortment of these types of parts.   If you call them they might be able to determine the correct part for you.
A picture of the real assembly would be useful.  A picture of the part removed would be even better.  Good luck.
Yes, if I was closer to the airplane, that would provide a definitive answer.  Maybe early tomorrow before it gets hot.  I just found it odd that, with thousands of parts specified in the IPC, this part would be neglected.
I don't have that IPC handy and you didn't show the entire drawing. Sometimes Mooney doesn't break out every part in the drawing. I'd check to see if the cable has an item number and then look that up in the parts list that goes with that drawing and see if there are other parts listed under that item.
Skip
2 hours ago, M20Doc said:
It’s listed under item #8 the control cable.  I can’t seem to post a screen shot at the moment
How do you do that?  If I had just moved my finger up an inch, I would have seen it.  Thanks.
Skip
Bingo!  You guys are good.
