Mcstealth Posted June 12, 2023 Report Posted June 12, 2023 (edited) Assuming you have the correct electronics to remove the vacume pump, what exactly is the procedure and need-to-do's to complete the job? Edited June 12, 2023 by Mcstealth Quote
EricJ Posted June 12, 2023 Report Posted June 12, 2023 22 minutes ago, Mcstealth said: Assuming you have the correct electronics to remove the vacume pump, what exactly is the procedure and need-to-do's to complete the job? Remove the hoses, the vacuum regulator, filter, and manifold (under the glare shield), and the pump. Plug the hole in the firewall where the hose used to go, and put the cover plate where the pump used to be. You can get the plate and a new gasket from AS or a number of places. The only real complication is that the plate is not as thick as the unthreaded shanks on the studs that held the pump in. The pump base is a lot thicker. You can get around this with an extra washer or two, which may earn side-eye from some, but imho it beats pulling the studs. The hole in the firewall is fairly large, since the hose is big. I plugged it with a couple large washers and a nut and bolt to hold them together on each side of the firewall. A little red RTV around the edges doesn't hurt. The plate, which can be fabbed if you're handy with metal: https://www.aircraftspruce.com/catalog/eppages/superior08-11778.php Edit: Removing the pump can be a pain without the right tool to get at the bottom nuts. If you don't have one and can borrow one, it'll save a lot of bad language. https://www.aircraftspruce.com/catalog/inpages/installtool.php 1 Quote
Mcstealth Posted June 12, 2023 Author Report Posted June 12, 2023 (edited) 2 hours ago, EricJ said: Remove the hoses, the vacuum regulator, filter, and manifold (under the glare shield), and the pump. Plug the hole in the firewall where the hose used to go, and put the cover plate where the pump used to be. You can get the plate and a new gasket from AS or a number of places. The only real complication is that the plate is not as thick as the unthreaded shanks on the studs that held the pump in. The pump base is a lot thicker. You can get around this with an extra washer or two, which may earn side-eye from some, but imho it beats pulling the studs. The hole in the firewall is fairly large, since the hose is big. I plugged it with a couple large washers and a nut and bolt to hold them together on each side of the firewall. A little red RTV around the edges doesn't hurt. The plate, which can be fabbed if you're handy with metal: https://www.aircraftspruce.com/catalog/eppages/superior08-11778.php Edit: Removing the pump can be a pain without the right tool to get at the bottom nuts. If you don't have one and can borrow one, it'll save a lot of bad language. https://www.aircraftspruce.com/catalog/inpages/installtool.php Wow. Thank you for that. Now a specific question. Fmodel with two G5's, 430w, 530, JPI-700, what needs to be done wiring wise, GPS wise, PFD wise, retractable step, etc, etc. I'm sure there is more to it than just the hardware. Thanks for the links. Edited June 12, 2023 by Mcstealth Quote
Mcstealth Posted June 13, 2023 Author Report Posted June 13, 2023 26 minutes ago, bluehighwayflyer said: If your F is PC equipped you will also have to remove that system. The aileron servos are a pain without a shorty ratcheting box end wrench. As you mentioned, you will need to install @takair’s electric conversion kit for your retractable step. I am guessing, the auto pilot is an S-Tech 50, that those are probably removed already? Thanks for the conversation kit tip. Quote
Mcstealth Posted June 14, 2023 Author Report Posted June 14, 2023 (edited) Nothing more specific to the panel instruments? I feel there is more to it but what do I know. As Anthony says, Not an A/P, and not experienced. Edited June 14, 2023 by Mcstealth Quote
EricJ Posted June 14, 2023 Report Posted June 14, 2023 46 minutes ago, Mcstealth said: Nothing more specific to the panel instruments? I feel there is more to it but what so I know. As Anthony says, Not an A/P, and not experienced. There are vacuum hoses that go to to the vacuum instruments. If you remove the instruments, remove the hoses and everything they're connected to. That's pretty much it. I think the only thing not mentioned is that there'll probably be a suction gauge with a small hose going to it, and potentially a warning light with a vacuum switch. All of that can come out, too. The vacuum system is essentially self-contained. There's not a lot of mixing of vacuum and electronic stuff, with the exception of the warning light that tells you when the vacuum quits. 1 Quote
