pilot-as14 Posted April 15, 2023 Report Posted April 15, 2023 Hello, After the repair of the main landing gear I was looking for the assembly tool to buy in Europe for a long time. Nothing found. Then I built this. Simple and works well. 2
Fly Boomer Posted April 16, 2023 Report Posted April 16, 2023 7 hours ago, pilot-as14 said: After the repair of the main landing gear I was looking for the assembly tool to buy in Europe for a long time. Nothing found. Then I built this. Simple and works well. It's a beast! (that is a good thing)
cliffy Posted April 17, 2023 Report Posted April 17, 2023 If the main gear is in the airplane you can use the weight of the plane to replace the rubber pucks. Jack up one side, swing the lower arm down and replace the pucks Then drop it down so the tire pushes the rubber pucks together and put the top collar on.
N201MKTurbo Posted April 17, 2023 Report Posted April 17, 2023 I saw a guy do it with a floor jack on the axel with the wing tied down. Seems kind of hard on the tie down hook.
