Getting ready to install the CGR Combo Engine Analyzer kit. Trying to figure out exactly where to mount the transmitter. Does anyone who has done something similar have a picture of the transmitter mounted and fuel lines?
Normally between the engine fuel pump and fuel injection servo.  Requires two new hoses.  The STC should state the location.  There was a recent thread about wrapping the transducer with fire sleeve.  It normally required.
I have a different engine monitor, but it’s right where doc says, right around/under the 2/4 intake/exhaust tubes under the pilots side of the engine.
Thank you. I know where it goes, was just looking for a picture, before I have the hoses made.
Here’s how Mooney mounted the Floscan 201B on the J. Not sure if the hose lengths are correct for the F or what transducer you are using. The bracket mounts to the engine sump above the intake tubes.
Awesome…thank you!
