Luci Posted June 29, 2022 Report Posted June 29, 2022 Got the engine back from overhaul, received it without alternator bracket… can anyone share a picture of how the alternator fan clears the front engine baffles? I have an old ford alternator. Thank you.
Yetti Posted June 29, 2022 Report Posted June 29, 2022 I can tell you that there are three different alternator brackets. Mine needs "shims" to make it line up. It is possible to install the bracket backwards. The Lycoming engine manual has all the information. If it went to the rebuilder with a bracket. I would expect the bracket back.
Guest Posted June 30, 2022 Report Posted June 30, 2022 7 hours ago, Luci said: Got the engine back from overhaul, received it without alternator bracket… can anyone share a picture of how the alternator fan clears the front engine baffles? I have an old ford alternator. Thank you. Typically there is no cooling fan on Mooney alternators. Clarence
