PTK Posted June 29, 2019 Report Posted June 29, 2019 I had the starter relay replaced recently at annual. It’s a Cutler Hammer 6041H105A. Does anyone know if there's someone out there who rebuilds these? Thanks in advance. Quote
kortopates Posted June 30, 2019 Report Posted June 30, 2019 Peter, I found exact OEM replacement solenoids for just under $200 but mine is a 28v system and may be a different part no since I installed the 6041H202 model, so this may not be an exact match but I didn't look for your number as much as what I used.https://www.peerlesselectronics.com/6041h202-relayI went this route, versus a generic solenoid as a minor mod, so that I wouldn't have to also alter wiring it. It's in a terrible spot to work on.Sent from my iPhone using Tapatalk 1 Quote
carusoam Posted June 30, 2019 Report Posted June 30, 2019 Not ever hearing of relay OHs.... And DanB came up with a similar relay challenge earlier... I did a brief search, and came up with a quick result... an aviation relay overhauler...? http://naasco.com/capabilities-2/silmet-solutions/ The relays they were talking about Look a wee bit larger, so the couple hundred dollar ones still probably get replaced... Peter, it might make an interesting phone call, with the part number in hand... PP thoughts only, not a mechanic... Best regards, -a- 1 Quote
PTK Posted June 30, 2019 Author Report Posted June 30, 2019 11 hours ago, kortopates said: It's in a terrible spot to work on. Thank you Paul. Indeed it is in a tight spot! And it seems Mooney selected the starter relay to economize on wire! At least in my plane they didn’t even put in an inch of extra slack in the wire! Quote
amillet Posted June 30, 2019 Report Posted June 30, 2019 13 hours ago, kortopates said: Peter, I found exact OEM replacement solenoids for just under $200 but mine is a 28v system and may be a different part no since I installed the 6041H202 model, so this may not be an exact match but I didn't look for your number as much as what I used.https://www.peerlesselectronics.com/6041h202-relay I went this route, versus a generic solenoid as a minor mod, so that I wouldn't have to also alter wiring it. It's in a terrible spot to work on. Sent from my iPhone using Tapatalk Paul, did you buy 1 or go for the $25.00 per unit discount and purchase $100 units? 1 Quote
