I read somehwere the accessory case muxt be changed to a different type and it is over 3,000$.  Plus the labor to swap out the cases (engine has to come off the mount) , and then you have to but two mags and harnesses.  Not cheap.
  • 7 months later...
Quote: Bill_Pyles
I have an IO360A3B6D like a lot of us.   So what is the "best" upgrade path if I want to get away from the dual mag?  Where would I get the new hardware and can any competant A&P install it or should I find a MSC to do it?  I live in Phoenix.
The mag will fail quickly if the capacitor is not well grounded. Make sure the threads are clean and the capacitor is in tight.
