GooD day to all am trying to find a swivel joint for the mixture rod end part number 660051-3 for my 1966 M20 E ! Can anyone tell me where to get one and what the cross numbers for aircraft spruce might be ! Thanks to all you good People!
Edited by Rodeo John
Doubled
There is a lot in this thread that may be helpful... like macfarlane...
But finding just that final detail may take more MS search skills than I have today...
The ball and socket rod ends are obsolete and have been replaced with a rod end bearing, a bolt and spacer.
The part number 660051-3 is no longer available!  Kit from mooney 660051-005 to replace the obsolete part ! Getting kit from Don Maxwell .  At least we have obtions! Thanks to all !
  • 2 years later...
Hi Clarence,
Could you please help me with which rod end bearing, bolt and spacer is going on F models these days?
I found this swivel type  https://www.aircraftspruce.com/catalog/appages/swivelbearing.php?clickkey=4183
https://www.aircraftspruce.com/catalog/appages/hmbrng.php?clickkey=4183
https://www.aircraftspruce.com/catalog/appages/aurorabearfem.php?clickkey=4183
Thanks!  Craig
HF-3 rod end bearings are the most common. I looked through the Mooney kit list and could not find the kit number. A quick shout to LASAR should get you fixed up with the kit or individual part numbers.
