mikefox Posted October 11, 2010 Report Posted October 11, 2010 I have an '89 M20J and the electric fuel pump is making some "squealing" noises when priming for engine start. I have two questions: 1. Anyone else experience a "noisy" electric fuel pump, and could it indicate that it is on its last leg? 2. If the electric fuel pump were to fail, is it possible to start the engine cold without it? Thanks, Mike
davidfreedman Posted October 11, 2010 Report Posted October 11, 2010 I had the same issue last year with my '83 J...I know that squealing sound you are describing. Got so bad that the boost pump switch wouldn't stay on for more than 10 seconds or so before tripping. I replaced the switch but that didn't do the trick. I ultimately replaced the pump and problem solved. No idea on question #2.
MooneyMitch Posted October 12, 2010 Report Posted October 12, 2010 You might try George's Electric in Sacramento. They did an overhaul for us a few years ago. Very reasonable and very timely service too. I believe the owner is Mike. Google search them for the contact information. You can start the engine without the electric pump, but it take more cranking time.
davidfreedman Posted October 12, 2010 Report Posted October 12, 2010 I should mention that I replaced my pump with a Weldon model A8163-A from Aircraft Spruce. It ran around $800 plus installation.
richardheitzman Posted October 12, 2010 Report Posted October 12, 2010 Listen to your aircraft, it is talking to you. Get is fixed before it fails. Any time something changes in the way the aircraft sounds, it needs to be looked at. Pull out your POH and find out how many times it tells you to turn on the fuel pump in an emergency.
Mckipper Posted January 4, 2012 Report Posted January 4, 2012 I also had a noisy aux fuel pump, (but not the squealing you discribe ). Ask a couple of pilots to listen, they all told me it sounded ok, less than 10 hours later the fuel pump switch tripped out, and the pump never ran again. I was away from my home airport, so started her by cranking. I have the high speed Skytech starter and a 3 week old battery, and it was touch and go if she would start up. Got a reconditioned Dukes unit, unit and fitting during the christmas week was ZAR 15999 ( $2000) in South Africa. Mine is a 1981 M20J.
M016576 Posted January 4, 2012 Report Posted January 4, 2012 Quote: mikefox I have an '89 M20J and the electric fuel pump is making some "squealing" noises when priming for engine start. I have two questions: 1. Anyone else experience a "noisy" electric fuel pump, and could it indicate that it is on its last leg? 2. If the electric fuel pump were to fail, is it possible to start the engine cold without it? Thanks, Mike
Rustler Posted January 5, 2012 Report Posted January 5, 2012 Mike-- Mine went south just before annual last year. No squealing but I noticed the scent of gasoline when landing. The casing had split, and gasoline was escaping from the rupture, a very dangerous situation. If the weather is warm enough, you should be able to start without using that pump, but that puts a greater load on the starter and battery. Not good. Mine cost $875 and $80 labor to exchange it.
byrdflyr Posted May 4, 2012 Report Posted May 4, 2012 I have an M20C, and just replaced the Dukes 440-00-21A fuel boost pump at $1000, returned my old pump (leaking), otherwise the core charge would have added $600.
