How does one change the bulb out of a mooney enunciator panel?
The gear down bulb no longer lights.
No light comes on when the test button is pushed.
Fortunately the gear is down with the floor mounted indicator and light bulb working properly.
Should I be looking for anything else?
Thanks,
- Anthony -
On my 1978 M20J, I remove the front panel of the annuciator and replace the lamp.  Mine uses a GE 330, 12v bayonet lamp. They cost about $1 at spruce, probably less at NAPA.
Lee
Thanks Lee,
I'll be heading to the airport armed and ready.  In  my case the  bulb is an extra 50 cents for the 24v version.  (GE 327)
