     We need a good Cleveland 40-24 wheel assembly (6.00x6 mains) with bearings.  This is the one with screw retained double  seal retainer plates on the outside and a screw retained cap on the inside.  I have new tires on hand .
     I also plan to replace both brake discs Cleveland 164-9 or 164-109.  So a servicable or new pair of these are also of interest (wear limit is .227inch min.).
      You can find me on the Members list, and send a private message that I will get by e-mail.  Or, just post here and I will send you a private.
Steve 65E-NC
Scott, Probably not.  Aircraft Spruce shows a different wheel for the J.  But, then it shows that exact same one for the C.  Don't know why a C and E would use different wheels.  Maybe some change depending on serial number or year of aircraft. You probably have to look at it to be sure.  I might be able to change over but then I would need two.
Thanks,
Steve
  • 4 weeks later...
