peter425 Posted January 14, 2013 Report Posted January 14, 2013 Tthe left brake pedal in my 231 lost all hydraulic fluid. There was evidence that fluid had leaked past the piston o-ring in the brake assy. I am replacing the o-ring and I am back bleeding the brake system through wheel cylinder bleeder valves using pressure pot. Using this method is there a need for pumping the brake pedals? Service manual states that the brake pedal should be "pulled back" (section 12-20-05). Any helpful suggestions out there from folks that have experience with brake bleeding mooneys. Does raising nose wheel off the ground help? What will be indication that the master cylinder needs servicing? Thanking you in advance for your help. peter lamberty N322DB Quote
N601RX Posted January 14, 2013 Report Posted January 14, 2013 Tthe left brake pedal in my 231 lost all hydraulic fluid. There was evidence that fluid had leaked past the piston o-ring in the brake assy. I am replacing the o-ring and I am back bleeding the brake system through wheel cylinder bleeder valves using pressure pot. Using this method is there a need for pumping the brake pedals? Service manual states that the brake pedal should be "pulled back" (section 12-20-05). Any helpful suggestions out there from folks that have experience with brake bleeding mooneys. Does raising nose wheel off the ground help? What will be indication that the master cylinder needs servicing? Thanking you in advance for your help. peter lamberty N322DB You can search for several previous threads on this. Be sure to flush all the old fluid out. If the wheel cylinders are pitted, the orings will not help. Here is what I used. $7 at lowes. Having someone inside moving the pedal back and forth slowly will help. Quote
