fatlasercat Posted December 9, 2025 Report Posted December 9, 2025 Anyone has a spare ASI that could be installed in a 2900GW M20J? We currently have a Sigma Tek 820308-525, but it's leaking and wouldn't pass pitot/static check. Thanks.
KSMooniac Posted December 9, 2025 Report Posted December 9, 2025 I went thru this last year and would advise you not to mess around with a used one unless you bench-check it first for leakage. Seals are not available for many of these old ones, unfortunately. I had Century Instruments in Wichita mark a freshly-overhauled United ASI for my J and would recommend that course vs. gambling on some salvage/used ones. 1
PT20J Posted December 9, 2025 Report Posted December 9, 2025 Check with Skylar Thody at Skyman Avionics 541-604-9573. I think he still has mine from my 1994 M20J MSE. It was working fine when removed for the G3X installation.
fatlasercat Posted December 9, 2025 Author Report Posted December 9, 2025 2 hours ago, PT20J said: Check with Skylar Thody at Skyman Avionics 541-604-9573. I think he still has mine from my 1994 M20J MSE. It was working fine when removed for the G3X installation. Thanks. I called them. This is what they have. Is it yours? Interestingly the v speeds are different on ours. https://www.skymanavionics.com/product-page/sigmatek-airspeed-indicator-40-210-kts
fatlasercat Posted December 9, 2025 Author Report Posted December 9, 2025 3 hours ago, KSMooniac said: I went thru this last year and would advise you not to mess around with a used one unless you bench-check it first for leakage. Seals are not available for many of these old ones, unfortunately. I had Century Instruments in Wichita mark a freshly-overhauled United ASI for my J and would recommend that course vs. gambling on some salvage/used ones. We're actually considering an avionics upgrade, so don't want to spend on the old equipment, just looking for a temp fix. We might just go VFR only until the upgrade. 1
PT20J Posted December 9, 2025 Report Posted December 9, 2025 (edited) 1 hour ago, fatlasercat said: Thanks. I called them. This is what they have. Is it yours? Interestingly the v speeds are different on ours. https://www.skymanavionics.com/product-page/sigmatek-airspeed-indicator-40-210-kts Yes, the ASI serial number matches mine. It’s Mooney part number 820308-535 which according to the IPC was used on SN 24-3201, 24-3218 on. The IPC lists several part numbers of ASI for various M20J serial numbers. EDIT. I see yours is a -525. Edited December 10, 2025 by PT20J
