markazzarito Posted March 19, 2025 Report Posted March 19, 2025 Im wondering if anyone has found a replacement solution for the thermos style gas caps? As the rubber goes bad the latches end up pulling through the thin aluminum I’ve replaced a couple but new ones dont exist from what i can tell anymore? another one of mine just failed and need a solution i have a 63 M20C
hammdo Posted March 19, 2025 Report Posted March 19, 2025 @Sabremech did a modern upgrade on the one I bought from him. Very nice. Both caps are like the Ovation version and readily available. -Don
47U Posted March 19, 2025 Report Posted March 19, 2025 13 hours ago, markazzarito said: Im wondering if anyone has found a replacement solution for the thermos style gas caps? Spruce sells these caps, as NOT FAA approved. But, if you got one and took parts off of it to rebuild your caps, then it’s a repair. Talk to your A&P/IA first. As long as they’re happy, you’re golden. 2
Brian2034 Posted March 19, 2025 Report Posted March 19, 2025 2.125 diameter https://www.mcmaster.com/catalog/127/2221/ 1
Mooneyintn Posted March 20, 2025 Report Posted March 20, 2025 i have a good set here from the same year plane. give me acall at 423-273-3557
bcg Posted March 22, 2025 Report Posted March 22, 2025 Spruce sells these caps, as NOT FAA approved. But, if you got one and took parts off of it to rebuild your caps, then it’s a repair. Talk to your A&P/IA first. As long as they’re happy, you’re golden. Napa sells a gas cap like that for about 1/2 the price, only difference is it's a screw compression instead of the flip tab. Disassemble it and use just the rubber piece to repair the Mooney cap, throw the rest in the scrap metal pile. Sent from my Pixel 9 Pro XL using Tapatalk 1
