TangoTango Posted February 4 Report Posted February 4 (edited) Hi all, I am the proud new owner of a 1993 M20J. In the process of getting to know her, I found this I reattached the SCAT duct, but it's pretty ratty. I think it's time to just go through and replace all of them under the cowl. I found this thread, but I cannot get either link mentioned to work. Is Gee-Bee Aeroproducts still making finished SCEET hoses? I also see customducts.net mentioned here as the successor to Jonathan Kinney. That link also doesn't work, but there's a website here by the same name. Obviously I could just go to Aircraft Spruce and order some regular ole SCAT duct, but I'd like to know what everybody else is using, and maybe I can find something more durable. Thanks! Edited February 4 by TangoTango Quote
Gee Bee Aeroproducts Posted February 4 Report Posted February 4 (edited) I have all versions in stock 1977 1978 on up Later version MSE lined clamps 2” finished ends Black sceet Edited February 4 by Gee Bee Aeroproducts Quote
dkkim73 Posted February 4 Report Posted February 4 @Gee Bee Aeroproducts Those look really slick. I was considering have the SCAT tubing replaced (by SCEET, similarly) during my upcoming annual this month. At least one SCAT tube had fallen apart on the initial annual last year, and I was thinking it would not hurt with my intermittent CO leaks to replace at least the heat and vent tubing. Do you have the specs/measurements for a set for the M20TN (type S if it matters)? Quote
Gee Bee Aeroproducts Posted February 4 Report Posted February 4 4 minutes ago, dkkim73 said: @Gee Bee Aeroproducts Those look really slick. I was considering have the SCAT tubing replaced (by SCEET, similarly) during my upcoming annual this month. At least one SCAT tube had fallen apart on the initial annual last year, and I was thinking it would not hurt with my intermittent CO leaks to replace at least the heat and vent tubing. Do you have the specs/measurements for a set for the M20TN (type S if it matters)? 3 minutes ago, dkkim73 said: @Gee Bee Aeroproducts Those look really slick. I was considering have the SCAT tubing replaced (by SCEET, similarly) during my upcoming annual this month. At least one SCAT tube had fallen apart on the initial annual last year, and I was thinking it would not hurt with my intermittent CO leaks to replace at least the heat and vent tubing. Do you have the specs/measurements for a set for the M20TN (type S if it matters)? I have all versions in stock 1977 1978 on up Later version lined clamps 2” finished ends Black sceet Quote
Gee Bee Aeroproducts Posted February 4 Report Posted February 4 It’s best to measure the I.d. Of the duct or the joining flange. Then the length end to end We Can mfg in a week or so Please use blue or white silicone adel clamps , not tyrap to secure. n77gb@msn.com we just finished some 1.5 x 64 long defrost ducts . My cross weave design gives the flex as scat single wall . Were double wall sceet Were the only mfg that can mfg 3” or 6” elbow drops . Quote
buddy Posted February 4 Report Posted February 4 I used Custom Ducts (customducts@gmail.com) 603-239-2345 last year and they did a great job. Quote
Gee Bee Aeroproducts Posted February 5 Report Posted February 5 17 hours ago, buddy said: I used Custom Ducts (customducts@gmail.com) 603-239-2345 last year and they did a great job. They don’t mfg there ducts they buy a roll and tape on the ends You must have a autoclave to produce assys . Do they supply Aerospace clamps ? There is a difference when you can provide certs with your product. Compare quality between products Good luck with that 1 Quote
hypertech Posted February 6 Report Posted February 6 I have used both custom ducts and geebee. Nothing wrong with custom ducts - the product is exactly as they say. But I think Geebee's are a bit better quality and I prefer them (also I like the black look). Also ship fast. Quote
Slick Nick Posted February 7 Report Posted February 7 @Gee Bee Aeroproducts do your ducts come with 8130’s? Quote
Gee Bee Aeroproducts Posted February 7 Report Posted February 7 Not required as the product is made to your specifications. Certification of conformance is required to tso / oem holders per there print . We have sold thousands of feet in various specs to the Airforce as were the only mfg that can do elbows with 3” or 6 “ drop 90 elbow . General aviation piston won’t pay the price for elbows. Quote
Slick Nick Posted February 7 Report Posted February 7 (edited) 15 hours ago, Gee Bee Aeroproducts said: Not required as the product is made to your specifications. It sure as heck is required here in Canada. At least a CoC stating that they're made to meet or exceed OEM specifications, or else nobody is going to be able to install them here. I like your workmanship, and I'd like to put these on my plane, but no Canadian mechanic will touch them without the proper paperwork. Edited February 7 by Slick Nick Quote
Gee Bee Aeroproducts Posted February 7 Report Posted February 7 Sold with certs only way to get 8130 is to purchase through mooney . I sell too many shops per there I.d. And length all over the world. And various mooney shops Check with your mechanic about ac43.13 m20 overhead vents homemade non finished ends vs finished ends 2 Quote
amillet Posted July 6 Report Posted July 6 @Gee Bee Aeroproducts How can I order. Having a hard time finding your website Quote
Gee Bee Aeroproducts Posted July 6 Report Posted July 6 Email n77gb@msn.com my beech store / website I have the dimensions of most models on file . inside diameter x Length Quote
