11 hours ago, drstephensugiono said:
Are the newer Acclaims all anti corrosion proofed internally?
The inside of the fuselage and the entire wing spar are primed with an anti-corrosion product.  Looking inside of the inspection panels on the wing, the rest of the areas are not treated with anti-corrosion.
I doubt that there's any product that can completely "corrosion-proof" aluminum.
