Was just curious why you can not weigh the airplane empty and then just mathematically add the 3 gallons of unusable fuel to make the empty weight?
You can, you just need to make sure it's actually fully empty, maybe by removing the sump drains and shaking it a lot.    You can also weigh it full and subtract it down to unusable, which is usually the easiest path.
Thanks. I figured both fuel caps off and drain plug removed with a shop vac blowing air through the wing would expedite evaporation of any fuel that might still be left in the tanks after the drain. Outside of course with a long shop vac hose to the tank. Don’t want the electric motor of the vac lighting off fuel vapors.
