Another great day with my Ovation (310 STC)! Flew from KHND to KAPV for a very expensive breakfast with a buddy - I started playing around a bit with the cruise settings to see the best combo of speed and efficiency. My preferred setting at 8-10k is around 21.7 MP/2500 RPM/15.7GPH yields a cruise speed around 175kTAS or so. Today I tried some different combos to see some more economical alternatives. I obviously have the POH engine charts (for both the Ovation and Ovation 3) - real world is relatively close. What do you my fellow MS’ers use?
For cruise, it is almost always full throttle and RPM 2500 and LOP 20 degrees. This usually gives me 175-180 knots depending on weight and the day and usually 14-15 gph. I can run it hotter/richer and get 182knots and 15-16gph. The Ovations really like LOP. I can give up a few knots at 50 degrees LOP and get down to around 12 gph. This may give me 168-172knots. Have fun getting to know your plane!
5 hours ago, EarthboundMisfit said:
Would love to see some engine page pics/data for your IO550.
WOT and LOP for us in cruise.  Typically 175TAS at 12.5GPH.  Our settings in the pics.
Have also posted a reel/video of our leaning procedure on FaceBook - https://www.facebook.com/reel/1433105633994967
5958BABB-566F-4843-88F2-BC20B7BEA820_1_105_c.jpeg.8a474d600e9747ac34358a4e1568ae3a.jpeg
This is really helpful. I’ll post some engine page pics on my next outing.
Same here - usually fly WOT, 10-12K, 10-20 LOP, yielding around 176-180 kts, 13.5-14.5 gph dep on conditions. Flaming dragon mode is 16-17 gph = 180-185kts (usually reserve this for lower or stiff headwinds when I need the time). Mine loves LOP - with GAMIs I can even run it much leaner than this without issues.
what prop setting?
16 hours ago, NickG said:
what prop setting?
2700 Takeoff 2550 in climb 2500 at altitude and 2400 at low altitude.
I can't believe the versatility of these planes. Cruised around today at a leisurely 160 KTAS or so at 65% power burning 12 GPH.
Can always go to my usual cruise of around 73-75% and go 174-178 KTAS on around 15 GPH .
Then there's "03 Mode" and get around 182 KTAS at 17 or so GPH.
  • 2 weeks later...
For me about 183 TAS at 14.1 at 9500.
  • 4 weeks later...
I'm going on about 2 years post installation. It was daunting to get them setup and dialed in but now, I really really like them. I have vertical tracking capability with autopilot flying ILS and RNAV approaches which to me is the bomb.
I'm still working on optimization of a few items (redundancy of mag for both 275's as an example which will give me heading if I have an electrical loss).
18 hours ago, EarthboundMisfit said:
@FJC Do you have an engine settings pic?  Aircon on yours?
I dont have engine parameters other than fuel flow (no temps but no issues at cruise). Yes, I do have air conditioning but almost never need it above 8,000.
3 minutes ago, FlyingScot said:
Butting in...going on 3 years. Love them.
Awesome! I spent a lot of time at Osh looking at those. Compared to the G5 I am used to, that display is just so much nicer.
Paired with a 750/650 and a gfc-500 these are amazing in the soup.
