Is the switch bad or just the cap?
@AH-1 Cobra Pilot now makes replacement caps for ETA switches.
The switch is actually a circuit breaker/switch. So, if it flips off and won't reset it might be due to a fault in the circuit. If the switch is indeed bad and you cannot find a replacement, you can often find a breaker switch with the same rating on eBay and get a new cap for it.
On 11/30/2023 at 11:19 AM, M20J Driver said:
Part # 930023-205 for a M20J - Need a replacement switch and so far no luck in finding one.  Might anyone have a suggestion as to where I could locate one? Thanks!
Hey @M20J Driver,
I think you asked this on Facebook as well.  Arizona Air Salvage does have a J they are parting out.  They may have the switch.
https://azairsalvage.com/product/1978-mooney-m20j-3538-9-aftt-lycoming-io-360-a3b6d-776-smoh-project-aircraft/
Regards,
R.Katz
