M20J Driver Posted November 30, 2023 Report Posted November 30, 2023 Part # 930023-205 for a M20J - Need a replacement switch and so far no luck in finding one. Might anyone have a suggestion as to where I could locate one? Thanks!
PT20J Posted November 30, 2023 Report Posted November 30, 2023 Is the switch bad or just the cap? @AH-1 Cobra Pilot now makes replacement caps for ETA switches. The switch is actually a circuit breaker/switch. So, if it flips off and won't reset it might be due to a fault in the circuit. If the switch is indeed bad and you cannot find a replacement, you can often find a breaker switch with the same rating on eBay and get a new cap for it.
katzhome Posted December 1, 2023 Report Posted December 1, 2023 On 11/30/2023 at 11:19 AM, M20J Driver said: Part # 930023-205 for a M20J - Need a replacement switch and so far no luck in finding one. Might anyone have a suggestion as to where I could locate one? Thanks! Hey @M20J Driver, I think you asked this on Facebook as well. Arizona Air Salvage does have a J they are parting out. They may have the switch. https://azairsalvage.com/product/1978-mooney-m20j-3538-9-aftt-lycoming-io-360-a3b6d-776-smoh-project-aircraft/ Regards, R.Katz
Aerodon Posted December 2, 2023 Report Posted December 2, 2023 I have spare switches, including Pitot. Send a PM. Aerodon
M20J Driver Posted December 2, 2023 Author Report Posted December 2, 2023 Thanks y’all! AZ Airsalvage has one on the way to me. ‘Preciate your responses!
