Yetti Posted April 15, 2022 Report Posted April 15, 2022 https://smacosports.com/products/smaco-heap-1-air-compressor-oil-free-built-in-water-oil-sepa-12v-300bar-4500psi?utm_medium=cpc&utm_source=facebook&utm_campaign=pump&fbclid=IwAR0UznI3CiVSYQw0miRRGqGfiPA1iu44ZGNK2LwRS0abnQmktJiDe3SQ-dQ SMACO Portable Air Compressor The SMACO electric pump is a compact and portable compressor that is suitable directly for PCP and scuba tanks. It is very convenient to fill your PCP air or scuba tank anywhere. The compressor is designed with a professional transformer that can decrease current loss and avoid damage to the pump to increase its service life. PCP Air Compressor Set-Pressure & Cooling Fan Portable Transformer Super Easy To Connect SMACO HEAP 1 Portable High-Pressure Air Compressor 4500psi for Filling $519.99 Quote
A64Pilot Posted April 15, 2022 Report Posted April 15, 2022 (edited) You need O2, not compressed air. ‘In tech diving we often used a “Haskell” to boost O2 pressure to fill our Deco tanks, Compressed O2 is a very dangerous thing, just a tiny bit of hydrocarbons and the tank may explode. Everything related to O2 in a dive shop has to be O2 clean, it’s really best left alone unless your trained to compress O2. https://www.tampabay.com/archive/2011/09/13/oxygen-behind-scuba-blast/ Edited April 15, 2022 by A64Pilot Quote
Sixstring2k Posted April 16, 2022 Report Posted April 16, 2022 21 hours ago, A64Pilot said: You need O2, not compressed air. ‘In tech diving we often used a “Haskell” to boost O2 pressure to fill our Deco tanks, Compressed O2 is a very dangerous thing, just a tiny bit of hydrocarbons and the tank may explode. Everything related to O2 in a dive shop has to be O2 clean, it’s really best left alone unless your trained to compress O2. https://www.tampabay.com/archive/2011/09/13/oxygen-behind-scuba-blast/ I second the leave it to the professionals if you can mentally. Quote
