Can anyone offer any information regarding the o-ring that holds the rubber servo boot in place on the fixed servo base of the step retract vacuum servo. I have a '68 M20F but I would expect it is similar/same for any model with a vacuum step retract servo. Ours has broken and I need to source a new one. Any info on vendors, part number, material, or dimension is appreciated.
Sent from my LM-V405 using Tapatalk
4 hours ago, moontownMooney said:
Yeah... it has disappeared :(
I'll check and see if there any reference in the info that Brittain sent me a few years back
  • 4 weeks later...
If anyone is interested, I was able to get all the details from Cecilia at Brittain. They use a Parker P/N: 2-042. This is a standard "-042" size o-ring meaning 3.25" ID, 3.375" OD, 1/16" bead width. It should be made of N674 compound with a hardness if 70 (N674-70) or equivalent or better. They use Seal Company Enterprises of Tulsa, OK. I found a suitable part matching these specs at www.theoringstore.com
  • 4 years later...
