Hi Rob,
So based on what you have told me and what I understand so far ....
Since my battery is in engine compartment   what size wire and how many wires would I need to run  back to the step ? I wanted to get head start.
Thanks,
James
2 minutes ago, jamesm said:
Hi Rob,
Thanks,
James
Assuming the beacon is in the tail, you need to run one 22g wire from the step to the battery and install a 1amp fuse at the battery.  If you PM me your email, I would happily send you an install manual.
I will try to get pictures of the install tomorrow.an error I posted yesterday was the bracket that my mechanic fabricated was down at where the cable attaches at the other end not the step end
