peevee Posted May 12, 2017 Author Report Posted May 12, 2017 47 minutes ago, takair said: Can you post pictures of the $500 replacement kit and how easy or hard to retrofit? This sounds like an underutilized alternative. I wish I had known about it when I was having problems. Sure. It didn't look bad to install to me. I didn't take pics of the doubler and stuff 940065_B.pdf 1
peevee Posted May 12, 2017 Author Report Posted May 12, 2017 37 minutes ago, takair said: I just realized there is another approved alternative. Safe Flight makes a drop in replacement AOA system. It fits in place of the stall switch we are discussing. While not cheap, if you are in the market for an AOA and need a stall switch, this may be the way to go and it may be less than doing both, a new switch and AOA. http://www.safeflight.com/product/scc-leading-edge-angle-of-attack/ I researched that a little and my impression was it wasn't approved to replace the stall warning system. Am I incorrect?
takair Posted May 13, 2017 Report Posted May 13, 2017 42 minutes ago, peevee said: I researched that a little and my impression was it wasn't approved to replace the stall warning system. Am I incorrect? You are right. I just looked again. The applicability used the words "had a safe flight transducer" and I assumed that meant you remove it. In fact, this is installed on the opposite wing and you must keep the old one. Good catch. Too bad, that would be a really great way to replace the switch and get an upgrade at the same time. By the way, I think that Mooney switch may be the way to go. It's a rare situation where the OEM part is more economical than the "aftermarket". That was a great find on your part and I think it will save people a lot of aggravation in the future. I guess all we had to do was ask!
peevee Posted May 13, 2017 Author Report Posted May 13, 2017 The part number is in the directions in the PDF above, for future searchers
