jhbehrens Posted March 15, 2009 Report Posted March 15, 2009 Hi there I fly an M20S Eagle and its about to get the Screaming Eagle STC from Midwest M20 that adds a 3-blade and 310 HP. The POH supplement provided with the STC is a little basic. So I'd like to get some more performance charts etc and I assume with the STC the plane's performance becomes pretty much identical to an Ovation 3. Does anyone have an electronic / scanned version of the Ovation 3 I could have? Please PM me. Many thanks! jhbehrens Quote
RobertoTohme Posted March 15, 2009 Report Posted March 15, 2009 Quote: jhbehrens Hi there I fly an M20S Eagle and its about to get the Screaming Eagle STC from Midwest M20 that adds a 3-blade and 310 HP. The POH supplement provided with the STC is a little basic. So I'd like to get some more performance charts etc and I assume with the STC the plane's performance becomes pretty much identical to an Ovation 3. Does anyone have an electronic / scanned version of the Ovation 3 I could have? Please PM me. Many thanks! jhbehrens Quote
RobertoTohme Posted March 15, 2009 Report Posted March 15, 2009 Oh, and congratulations on the conversion! You'll have a blast with it.... Who's doing the conversion for you? Quote
jhbehrens Posted March 16, 2009 Author Report Posted March 16, 2009 I'm based in the Netherlands (Europe) so its a Dutch shop. Justin from M20 tells me its not a specialist job. Quote
Cross Timbers Aviation Posted August 4, 2022 Report Posted August 4, 2022 (edited) I recently purchased a Screaming Eagle and am looking for good performance numbers as well. We’re you able to get good charts for the 310hp conversion? Edited August 4, 2022 by Cross Timbers Aviation Quote
ilovecornfields Posted August 4, 2022 Report Posted August 4, 2022 Holy Necrothread, Batman! Ovation3 STC.pdf 1 1 Quote
Jeff_S Posted August 5, 2022 Report Posted August 5, 2022 Here's an electronic POH for an Ovation 2. Note that the only real differences between the 2 and 3 are those found in the STC docs that Mr. Cornfields posted earlier, although this will now help you more since the Ovation had significantly different power available than the Eagle did. Hope this helps! m20rAFM.pdf 1 Quote
ilovecornfields Posted August 5, 2022 Report Posted August 5, 2022 42 minutes ago, Jeff_S said: Here's an electronic POH for an Ovation 2. Note that the only real differences between the 2 and 3 are those found in the STC docs that Mr. Cornfields posted earlier, although this will now help you more since the Ovation had significantly different power available than the Eagle did. Hope this helps! m20rAFM.pdf 5.11 MB · 1 download 2 Quote
Jeff_S Posted August 5, 2022 Report Posted August 5, 2022 1 hour ago, ilovecornfields said: 1 2 Quote
ilovecornfields Posted August 5, 2022 Report Posted August 5, 2022 49 minutes ago, Jeff_S said: Very well. I accept your meme challenge. 4 2 Quote
Jeff_S Posted August 9, 2022 Report Posted August 9, 2022 On 8/5/2022 at 3:47 PM, ilovecornfields said: Very well. I accept your meme challenge. 1 Quote
