Mooneymite Posted January 26, 2014 Report Posted January 26, 2014 I noticed that I mispelled "Control Shaft" in a recent topic heading. I typed "Contol" instead. Is there any way to edit the mis-spell? The problem is that the topic won't show up in a search for "Control Shaft" under the bad spelling. Quote
NotarPilot Posted January 26, 2014 Report Posted January 26, 2014 Look to the left of the button on your post (Lower right side) that says "Multiquote" to the right it should say "Edit" in lighter gray letters. Try clicking on that. Then click on the "Use Full editor" button right next to "Save Changes". That should allow you to change your heading topic. Quote
Mooneymite Posted January 26, 2014 Author Report Posted January 26, 2014 Great! Thanks. At first it wouldn't work, because I didn't realize I had to edit the very first post in the sequence. Quote
