Does anyone know if there is an LED drop in replacement for the U327 bulb.  Mine seem to go out regularly.  They're cheap, $0.22 at SkyGeek but they just don't last very long.
Great.  Thanks.  Any idea if the center contact should be positive or negative?
Midget Flanged Based LED, T1-3/4 (5mm) Energy-Saving Miniature Lamp
I was wondering the same thing. I imagine using a multimeter will be able to tell you. I'm going to check mine.
Does anyone know if it's legal to install one of these LED bulbs on a certificated aircraft?
Thanks.  I didn't realize the AC version would work in a 12 or 24 V DC environment.  That would make it easier.  The cost for the incandescent vs LED isn't the issue as much as reliability and power consumption.  Okay, power consumption isn't an issue either with these little bulbs but reliability is.
