EarthboundMisfit Posted September 13, 2024 Report Posted September 13, 2024 We are experiencing an intermittent static issue with our G1000 COM1 radio. If anyone has had this before, and solved it, we would be grateful for insight. All steps taken so far have been suggested by Garmin, but no resolution yet. Symptoms Intermittent static above approx. 4500’ on some freqs but not others. It sounds like the COM has been set to manual squelch. Video Troubleshooting steps so far Increased the squelch threshold. Issue seemed to be resolved, but then returned. Static wicks checked for continuity COM1 antenna verified as the forward antenna. Grounding OK, no corrosion, wiring continuity OK. Swapped GIA’s over - issue stayed on COM1 Update - 15 October Thanks all for the suggestions so far. We plan to try swapping antennas next. Confusingly, on the last several flights, the COM1 squelch noise hasn't been present. Recent work done was the replacement of worn alternator brushes (two flights ago).
GeeBee Posted September 13, 2024 Report Posted September 13, 2024 How about swapping antennas? There is usually enough slack to swap the antenna leads. 1
McMooney Posted September 13, 2024 Report Posted September 13, 2024 so probably not your issue but worth a try, mine was the audio panel, had to remove, clean and reseat it. I would get static and random times, across both radios ; would happen mostly when changing attitudes.
AVDB Posted October 9, 2024 Report Posted October 9, 2024 try at the end, when all the previous actions will not give the proper effect go to Configuration Mode -> GMA 1347 Configuration Page -> change Master Avionics Squelch
AVDB Posted October 9, 2024 Report Posted October 9, 2024 In the configuration mode, please take a picture of the COM 1 and COM 2 settings -> squelch threshold for 25 kHz and 8,33kHz channel spacing 1
JustusSJ Posted October 9, 2024 Report Posted October 9, 2024 How about swapping antennas? There is usually enough slack to swap the antenna leads.Yep. I would try that as well.Have seen some antennas go bad, even causing the EGTs to spike in the G1000 when transmitting Gesendet von meinem XQ-DQ54 mit Tapatalk 1 1
