JoeM Posted August 30, 2024 Report Posted August 30, 2024 I have my G430 tray out (for another upgrade) and would like to prewire the GPS connectors for dual G5s. I believe the ADI requires two RS232 on pins 56/57. Are there other connections to the 430 for the CAN bus or HSI that I should prewire as well? Also, I am running the wire in the wing for the magnetometer and wondering how many wires I will need? TIA Joe
McMooney Posted August 30, 2024 Report Posted August 30, 2024 the installation manuals are available from fly.garmin.com 2
PT20J Posted August 31, 2024 Report Posted August 31, 2024 Try https://support.garmin.com/en-US/?partNumber=K10-00280-01&tab=manuals
MB65E Posted August 31, 2024 Report Posted August 31, 2024 Make sure the software version on the 430, matches the drawing you have. On the 530 with current software. The lower connector no longer uses pins 60-64. The RS232 needs to go into the upper connector for rs232. The drawing I had said that 60-64 were available for RS232. Wired everything up…. No 232 data!!! -Matt
