Kodiakflyer Posted August 23 Report Posted August 23 Does anyone have a source for the 3CRE-714 shock disc? Quote
Sabremech Posted August 24 Report Posted August 24 Those are the old Firestone disks and are un-obtainium new. I just removed a set from my M20 and am complying with Mooney S/B M20-161 to install the later style Lord disks. David Quote
Kodiakflyer Posted August 27 Author Report Posted August 27 Which model do you have David? Mine is an A. Tom Kodiakflyer@gmail.com Quote
Kodiakflyer Posted August 27 Author Report Posted August 27 Never mind David. I read your thread. My project is similar 30 months in and have not made it public. 4 Quote
Kodiakflyer Posted August 27 Author Report Posted August 27 David, have you located the parts required to comply with M20-161? The Lord discs are easy...Spruce. It's the rest... Quote
Sabremech Posted August 28 Report Posted August 28 10 hours ago, Kodiakflyer said: David, have you located the parts required to comply with M20-161? The Lord discs are easy...Spruce. It's the rest... Hi Tom, I purchased the used parts I needed from Alan Fox. I believe he’s on MS but can message you his contact info if needed? Thanks, David Quote
Sabremech Posted August 28 Report Posted August 28 22 hours ago, Kodiakflyer said: Never mind David. I read your thread. My project is similar 30 months in and have not made it public. Great looking bird! Quote
LANCECASPER Posted August 28 Report Posted August 28 17 hours ago, Sabremech said: Hi Tom, I purchased the used parts I needed from Alan Fox. I believe he’s on MS but can message you his contact info if needed? Thanks, David @Alan Fox Quote
Kodiakflyer Posted November 23 Author Report Posted November 23 Hi Alan, sorry for the late reply. I don't visit this BB often. Wentworth had C gear that I scavenged the parts that I needed from. After cleaning, inspecting and painting, they look and fit up perfectly. Tom Quote
