*****SOLD******
1979 Mooney M20K Rocket 2650TT 940 SFREM/Rocket Conversion TSIO520, 705 SPOH times will go up as the aircraft is currently being flown
TKS, Speed Brakes, Monroy Long Range Tanks 101gal usable
Dual Garmin 430Waas, 1090 ES ADSB IN/OUT Garmin 345 installed May 2024, MX20 MFD, KFC200 Autopilot, Flight Director, HSI, Engine Monitor
Extensive annual completed in April 2024 to include Turbo Overhaul by Main Turbos, 500hr on both Magnetos, Prop sent out for IRAN due to age between overhaul. Prop Governor overhauled, Engine driven fuel pump overhauled, Alternator and coupler sent out for IRAN and new brushes and springs installed in the alternator, new spark plugs, Exhaust inspected, repaired and coated, new gear donuts on both mains and nose, new Goodyear tires and Michelin tubes, Landing Gear painted, replaced engine mounts.
Interior redone in 2001, good shape. Paint is original and was touched up March of 2024 Everything works as it should.
Aircraft sat in the Hangar from 2016 to 2024.  IFR check completed March 2024.  It has been flown over 30hrs since April 2024.
$189,000 located in Georgia
404-275-9543
