Zippy_Bird Posted March 15, 2024 Report Posted March 15, 2024 Ebay is your friend in this department. There are servos there to be had.Hi @McMooney, Used Servos can be had on eBay but my experience has been mixed. I’ve bought some excellent ones with supple rubber, clean, and perfect function. I’ve also paid good money for dogs… dry, dirty, leaking, useless. I’ve found that if the listing does not specifically state “excellent condition” beware. It is also my opinion that if a pilot is selling they are usually in good shape, but if a scraper is selling, rubbish.Sent from my iPhone using Tapatalk Quote
McMooney Posted March 15, 2024 Report Posted March 15, 2024 1 hour ago, Echo said: Ebay is your friend in this department. There are servos there to be had. it was a new boot, not from EBAY man wish I hadn't lost the contact Quote
Zippy_Bird Posted March 15, 2024 Report Posted March 15, 2024 I heard a rumor, a whisper on the wind, that someone found a replacement for these servo rubber boots. I have no proof of this, but I’d like to know if it is true and what. I have some useless servo cans sitting around. Mind you this would be for tinkering entertainment only and nothing that would ever go in a certified airplane. Would appreciate a PM if you know something! Thanks, ZSent from my iPhone using Tapatalk Quote
takair Posted March 15, 2024 Report Posted March 15, 2024 55 minutes ago, Zippy_Bird said: I heard a rumor, a whisper on the wind, that someone found a replacement for these servo rubber boots. I have no proof of this, but I’d like to know if it is true and what. I have some useless servo cans sitting around. Mind you this would be for tinkering entertainment only and nothing that would ever go in a certified airplane. Would appreciate a PM if you know something! Thanks, Z Sent from my iPhone using Tapatalk Pm sent Quote
Shadrach Posted March 18, 2024 Report Posted March 18, 2024 On 3/15/2024 at 12:45 AM, McMooney said: this was caused by a leak in one of my servos, bike patch and some electrical tape took care of it for a bit. then had to beg and plead to find a replacement. really wish i could remember who sent me the servo boot, i could really use more Might have been me. Do you currently need one? Quote
Echo Posted March 18, 2024 Report Posted March 18, 2024 At risk of triggering the marketing and sales departments of the "electric replacement" folks...It would be nice if a pretty low exposure (for failure of product...as step just stays down) step rubbeer membrane replacement was completed. I will add that to the "whisper on the wind"...from a guy that likes the simplicity of the vacuum step. Cue responses (already hashed and rehashed elsewhere) that ultimately gain financial benefit. Quote
Echo Posted March 18, 2024 Report Posted March 18, 2024 Just now, Echo said: At risk of triggering the marketing and sales departments of the "electric replacement" folks...It would be nice if a pretty low exposure (for failure of product...as step just stays down) step rubbeer membrane replacement was completed. I will add that to the "whisper on the wind"...from a guy that likes the simplicity of the vacuum step. Cue responses (already hashed and rehashed elsewhere) that ultimately gain financial benefit. To quote Ralphie: "A crummy commercial. Son-of-a-bitch." Quote
lvflyer Posted April 29, 2024 Report Posted April 29, 2024 On 3/14/2024 at 2:49 PM, Vance Harral said: I have no doubt most shops can overhaul the gyro part of a Brittain TC. Less sure about the shuttle valves and associated roll trim mechanism inside that device, though my guess is it's not complicated machinery. Our Brittain TC requires nearly full right roll trim for the wings to actually stay level, and we've contemplated "doing something" about that for a long time. We've verified rigging (airplane stays wings level in in still air with balanced fuel tanks and PC disabled), and we've also verified good vacuum hold on both the "left" and "right" tubing systems that connect to the TC, via a test rig. So the off-center problem has got to be in the TC itself. Haven't done anything about it because it's not really a serious issue. But the TC hasn't been out of the panel in at least 30 years (per notes from prior owner) and nothing lasts forever. Good to know there is, at least at the moment, a specialty shop that deals in these things. I have an issue with mine too. Please keep us informed if you do make contact with Kevin regarding overhaul of TC. Mine sat for so long the small rack and pinion mechanism corroded and broke. It's really tiny. I now can adjust it with a rod, but that is inconvenient and not real precise. I need a new rack and pinion set up on mine. Dirk Quote
takair Posted April 29, 2024 Report Posted April 29, 2024 3 hours ago, lvflyer said: I have an issue with mine too. Please keep us informed if you do make contact with Kevin regarding overhaul of TC. Mine sat for so long the small rack and pinion mechanism corroded and broke. It's really tiny. I now can adjust it with a rod, but that is inconvenient and not real precise. I need a new rack and pinion set up on mine. Dirk I believe I have an old ad still with a TC for sale that I bought as a package from someone else. Also, Kevin sometimes visits here. @Kevin Westbrook Quote
Zippy_Bird Posted August 24, 2024 Report Posted August 24, 2024 Hi All, sorry for the late reply. Been away from MooneySpace for too long.Kevin Westbrook is still going strong and earlier this year rebuilt, tested, and 8130’d a number of Brittain PC parts through Porter-Straight for me. These included a pilot control value, a servo control valve, a brittain basic PC gyro, a B-11 accutrack, and a B-12 accuflight. Cecilia at Brittain sent across the STCs for my bird at no cost! Can’t beat that. Also have a spare TC I considered sending over for rebuild, quoted $850 at the time, but my setup doesn’t need one. Highly recommend contacting Kevin and sending your brittain parts over for rebuild while you can!Sent from my iPad using Tapatalk 2 Quote
