ArrowBerry Posted February 26, 2024 Report Posted February 26, 2024 We recently completed and passed the AD for the control wheel shafts. Out of curiosity I looked on eBay and some salvage sites to see what the theoretical cost and availability would be in having to replace one of them. I noticed that for the same advertised part number, some shafts have a small bearing or something it looks like in the centre and some don't? If I remember correctly ours did not, but what's the difference? Are the interchangeable? And why are they advertised with the same part number if they aren't the same? The part number in question is 72005-1, which is the LH control wheel. These are the two ads right on top of each other on eBay I was contemplating. Quote
Igor_U Posted February 27, 2024 Report Posted February 27, 2024 16 minutes ago, ArrowBerry said: We recently completed and passed the AD for the control wheel shafts. Out of curiosity I looked on eBay and some salvage sites to see what the theoretical cost and availability would be in having to replace one of them. I noticed that for the same advertised part number, some shafts have a small bearing or something it looks like in the centre and some don't? If I remember correctly ours did not, but what's the difference? Are the interchangeable? And why are they advertised with the same part number if they aren't the same? The part number in question is 72005-1, which is the LH control wheel. These are the two ads right on top of each other on eBay I was contemplating. I think this bushing is a separate p/n 914020-22 and you get it included with the sale. Don't expect from the sellers to know all the intricacies of reading IPC or spending too much time on it. Good luck. Quote
ArrowBerry Posted February 27, 2024 Author Report Posted February 27, 2024 1 hour ago, Igor_U said: I think this bushing is a separate p/n 914020-22 and you get it included with the sale. Don't expect from the sellers to know all the intricacies of reading IPC or spending too much time on it. Good luck. Okay I understand, that's a good eye. When I look at the part diagram I see it now. Thanks for clarifying that. Quote
Kelpro999 Posted February 28, 2024 Report Posted February 28, 2024 On 2/26/2024 at 3:51 PM, ArrowBerry said: I looked on eBay Use extreme caution relying upon sellers part numbers. Attempt verifying with a/c serial number of donor a/c with yours. Even then measure everything. I have more than enough mistakes ready to resell. Quote
ArrowBerry Posted February 28, 2024 Author Report Posted February 28, 2024 20 hours ago, Kelpro999 said: Use extreme caution relying upon sellers part numbers. Attempt verifying with a/c serial number of donor a/c with yours. Even then measure everything. I have more than enough mistakes ready to resell. Noted... not everyone is as skilled with a parts manual, or cares to do the research, as a buyer would like. Quote
Kelpro999 Posted February 29, 2024 Report Posted February 29, 2024 19 hours ago, ArrowBerry said: Noted... not everyone is as skilled with a parts manual, or cares to do the research, as a buyer would like. Not only that you’ll find that most airframe parts were hand finished in place, meaning part holes from another plane will not match yours. It takes some mold and drill guide fabrication to fit new or used parts. Quote
