Htmlkid Posted October 9, 2023 Report Posted October 9, 2023 (edited) Does anyone have a forflight profile on this aircraft? Edited October 9, 2023 by Htmlkid Quote
toto Posted October 9, 2023 Report Posted October 9, 2023 3 minutes ago, Htmlkid said: Does anyone have a forflight profile on this aircraft? I don’t have ForeFlight, so I can’t help there - but basically any J model or 201 profile should work if you have a 2740# gross weight. If your aircraft has a 2900# gross weight then use an MSE profile. Quote
1980Mooney Posted October 9, 2023 Report Posted October 9, 2023 In Foreflight go to "Aircraft" Go to "Aircraft Type" In the drop down type "Mooney" or scroll down Within "Mooney" scroll down to M20J You will see a "M20J 205" with your planes flight profile already populated. Quote
