davesly Posted May 24, 2023 Report Posted May 24, 2023 Thanks everyone for the help so far in finding parts. I thought I would share my new Mooney Resurrection project. The pics on this post show the plane, about 10 years ago before, and after the hangar accident as well as how I purchased it last month (It came with the cowling and inspection panels). Thanks to the help from people on this board, I now have an engine, prop and baffles. I'll be posting pics of the restoration in this new topic. My goal is to keep the interior and exterior original, but have a nearly zero time mechanicals and a full Dynon glass Avionics system with GTN 650 or 750 GPS. 3
davesly Posted May 24, 2023 Author Report Posted May 24, 2023 Here is a pic of the zero time overhauled IO-360-A1A with 100 hour slick mags (4345/4370 with SlickStart). Mechanically, I'll be installing the following: new Sky-Tec Starter (NL) new Power-plane AL12-P70 Amp Alternator PCU-5000 Governor ATH1 new mechanical Fuel pump it had a new Electric boost pump installed at the accident annual ditching the vacuum pump new Powerflow exhaust system 120 hour SPOH (100 hr Eddy-Current required AD prop) to start with New Mixture and Throttle cables (mine are a bit sticky) New Fuel/Oil Hoses Rebuilt Oil cooler Blasted and powder coated engine mount with AD gussets welded in New Lord engine mounts and engine mount-firewall hardware 4
Denis Mexted Posted May 24, 2023 Report Posted May 24, 2023 Best of luck davesly. I'm about half way through my own F model reno. VH-KWA. 1
davesly Posted May 26, 2023 Author Report Posted May 26, 2023 I decided to go with the Garwin 34-828-014 governor instead of the PCU-5000. After feedback from some members, I found that Mooney used two types of governors based on where the prop cable comes out of the firewall. Mine comes out on the left (pilot) side and mounts to a triangular aluminum bracket (see picture). Other planes (prior to 1969) used a piece of 90-angle-aluminum extrusion mounted up and to the right for the cable coming off the right side of the firewall. It appears that the default configuration of the PCU-5000 is to replace this right-hand style of Hartzell Governor and thus the rotation and indexing of the ATH-1 requires reconfiguration for my mount type. In order to make things simpler, I opted to just go with an overhauled Garwin $1,550 which is also about 1/2 price. Additional research shows the 34-828-014 being used on both 0-360 and IO-360 for all Mooney models in 1969 (probably other years also).
davesly Posted November 5, 2025 Author Report Posted November 5, 2025 The new engine is in, prop and exhaust installed. Just hooking up the details. We have a new mechanic at Freeport, IL now who is familiar with Mooneys. Progress moving much faster now. 5
