bcg Posted May 1, 2023 Report Posted May 1, 2023 I have the original style strobe on my C and when it flashes, I hear a sound in my headset and see a pretty big bounce in my ammeter, oil temp and oil pressure gauges in the original, analog instruments. I'm replacing those with a JPI EDM-930 when I do my annual, which I hope will make the bounce less noticeable but, I'd really like to get rid of the sound in the headset/comms as well if I can. Would replacing the strobe with an LED accomplish that? Quote
ArtVandelay Posted May 1, 2023 Report Posted May 1, 2023 They should, I don’t know anyone who’s had a problem with LEDs. Quote
bcg Posted May 1, 2023 Author Report Posted May 1, 2023 Another question, what's the best option to replace the beacon strobe on the bottom of my C? The one I have currently is clear/white. Quote
haymak3r Posted May 1, 2023 Report Posted May 1, 2023 Before I upgraded my avionics, I heard the same thing. I could hear the powersupply charging up every flash. I feel like it was my old archaic audio panel and some sort of grounding issue. I don't hear it in my headset anymore. It's very nice. Quote
bcg Posted May 1, 2023 Author Report Posted May 1, 2023 On 5/1/2023 at 10:08 PM, haymak3r said: Before I upgraded my avionics, I heard the same thing. I could hear the powersupply charging up every flash. I feel like it was my old archaic audio panel and some sort of grounding issue. I don't hear it in my headset anymore. It's very nice. Expand I wouldn't be surprised if it's a grounding issue. Based on some other stuff I've seen done in the avionics, I'm pretty certain things were grounded to the aircraft body instead of running everything back to a central grounding bus. It's something I'll be looking into when we're working on everything else, there's going to be a lot of changes made to the wiring anyway replacing all the gauges so I might as well straighten it all out at the same time. 1 Quote
