Brian Mills Posted March 4, 2023 Report Posted March 4, 2023 Getting ready to install the CGR Combo Engine Analyzer kit. Trying to figure out exactly where to mount the transmitter. Does anyone who has done something similar have a picture of the transmitter mounted and fuel lines? Quote
Guest Posted March 4, 2023 Report Posted March 4, 2023 Normally between the engine fuel pump and fuel injection servo. Requires two new hoses. The STC should state the location. There was a recent thread about wrapping the transducer with fire sleeve. It normally required. Quote
Ragsf15e Posted March 5, 2023 Report Posted March 5, 2023 I have a different engine monitor, but it’s right where doc says, right around/under the 2/4 intake/exhaust tubes under the pilots side of the engine. Quote
Brian Mills Posted March 5, 2023 Author Report Posted March 5, 2023 22 hours ago, Ragsf15e said: I have a different engine monitor, but it’s right where doc says, right around/under the 2/4 intake/exhaust tubes under the pilots side of the engine. Thank you. I know where it goes, was just looking for a picture, before I have the hoses made. Quote
PT20J Posted March 6, 2023 Report Posted March 6, 2023 Here’s how Mooney mounted the Floscan 201B on the J. Not sure if the hose lengths are correct for the F or what transducer you are using. The bracket mounts to the engine sump above the intake tubes. Quote
Brian Mills Posted March 6, 2023 Author Report Posted March 6, 2023 15 hours ago, PT20J said: Here’s how Mooney mounted the Floscan 201B on the J. Not sure if the hose lengths are correct for the F or what transducer you are using. The bracket mounts to the engine sump above the intake tubes. Awesome…thank you! Quote
