Which pressure are you worried about?   They all seem okay.
Edit:   I'm guessing you mean manifold pressure.   At 10kft that does seem high if you don't have a turbo.    When on the ground you can compare it to your altimeter setting with appropriate conversions for field elevation to determine whether it is off or how much.
There is no calibration on the G3X for manifold pressure, so it is most likely a bad transducer. It’s also good to check that the tiny drain hole in the line is clear to keep liquid from making it’s way to the transducer.
