jM20 Posted February 14, 2022 Report Share Posted February 14, 2022 The white looking shock absorber is attached to the nose wheel linkage. The image is the port panel area next to the nose wheel compartment. Any idea what it is? Part number? I can't find anything about it in the service manual.. Quote Link to comment Share on other sites More sharing options...
cliffy Posted February 14, 2022 Report Share Posted February 14, 2022 Its the rudder system bungee (similar to the elevator bungees) that should be set for zero force when the rudder system is rigged with the copilot pedals blocked to even setting. It adds to the rudder/nose wheel centering force both on the ground and in flight Figure 6-5 in the maintenance manual. Quote Link to comment Share on other sites More sharing options...
jM20 Posted February 20, 2022 Author Report Share Posted February 20, 2022 Thank You!!! Quote Link to comment Share on other sites More sharing options...
