If properly setup, you should be seeing right around 18 GPH for a standard day, sea-level full-rich takeoff.  It will decrease as you climb, or for hotter days.  You can also lean in the climb using the Target EGT method to make a more efficient climb.
My 200hp J did something like 18.2 gph at 500' MSL and climbing, IIRC (WOT and mixture full rich).  It shouldn't be much (if any) lower than that.  Otherwise you're max fuel flow is too little for that kind of power setting.
Quote: jax88
Anyone with a F model care to share their observed fuel burn during the climb with me?
I don't fly from the coast very often, but mostly from airfields at an average of 4000 ft. At this alt, my fuel flow during climbs is usually around 16 gal/hr.
