Mike,
To hopefully help with your search.....
are you refering to the outer bezel that holds the switch in place.  (I think if this threaded piece, knurled on the outside, is missing, the whole switch is loose in the hole in the panel?)
This may be a Bendix switch part, not so much a mooney decoration....?
Good luck in your search.
- a -
I have the old switch that I removed from my plane.  Aircraft spruce also sells a replacement that comes with a matching keyed door and baggage door lock.
