Browncbr1 Posted May 31, 2016 Report Posted May 31, 2016 I need one of the Brittain AH on/off valves to put in my panel so that I can bypass the yoke button, as a master PC on/off valve... I've seen a few brittain installs with this setup with field approval.. Hoping someone has one they aren't using... Panel On-Off Valve 1966 Mooney.pdf Quote
sdflysurf Posted April 5, 2021 Report Posted April 5, 2021 Did you ever find one? I'd like to put my PC control into the panel as well, hoping for a pneumatic switch that the IA would be ok with since the Brittain 11516 is no where to be found. Quote
