Hi all
I have a mooney m20e with electric gear.
Testing the manual emergency retracting system I found out that it does not work due to failure in the mechanism inside the "Dukes drive connector" which acts as a clutch that connects/disconnects the cable for the emergency extension handcrank.
The problem may be the cable and the dukes drive connector (diagram attached).
Any one for sale out there?
Thanks!
To clarify, there is a steel spline coupling inside the drive connector, and that is what failed. Easy fix now that they are supplying that part. It was not available a few years ago...
Sent from my VS985 4G using Tapatalk
