Hot topic of debate (at least in my circle).
Some swear by the original POH's =full rich until altitude=, others by the 1400 TIT indication discussed by several Mooney engineers via MAPA.
Let the games begin!
Check out Bob Kromer's test flight of the 231 in the sample articles on the MAPA web site.  It is a pretty good article, seems to be objective, and is ONE opinion as to how to best fly the 231.
I'd agree it seems to be a good article, but I'd ignore the 50 ROP recommendation--but that's at cruise, not in climb.
50 ROP is almost the worst mixture setting to run an engine, especially one making more than 65% power which is easy to do with a K at any altitude.  40 ROP is the worst.
Just about any mixture setting would be better than 50 ROP, but 50 LOP would be better than at peak.  Really, though, it depends on the power setting--at or below around 60%, it doesn't really matter.  More than that, though, and you'll want to avoid the so-called "red box":
  • At 65% power, use richer than 100 ROP, or leaner than peak EGT.
  • At 70%, use richer than 125ºF ROP, or leaner than 25ºF LOP.
  • At 75%, use richer than 180ºF ROP, or leaner than 40ºF LOP.
  • At 80%, use richer than 200ºF ROP, or leaner than 60ºF LOP.
(see http://www.avweb.com/news/pelican/182583-1.html for the source of this data and further dicussion).
