Folks, I attempted to remove the rear seat in my Mooney with no success. There are two spring loaded pins on each corner in the rear. With both pulled out, the seat was still secured in the center. There also appears to be a pin in the center with a very small set screw. If it is a set screw, it is broke off. There are also multiple sets of steel flat brackets on both sides which I assume are for seat support ?  I like to be able to remove the seat to inspect the main spar as well as for loading purposes. Your input is appreciated.  Tks  Tom
If you fully disengage the pins on each side they will come out.  After the pin is pulled move that side of the seat forward.  You may also need to release the recline mechanism.
