Hi everyone,
been a while since i came here ! first time i post on the new board...
I was wondering if any of you knew where i could find what's in the title (POH for M20J and 252 in electronic format).
I'd like to know these two better  ;)
Thanks in advance for your help !
Thanks both of you !
@Awful charlie : pretty comprehensive list ! so much so thath i dont really know what i'd need to order from this page ...
Master Library is just everything ? or is it extra information not contained in other publications ?
I am having a problem with the fuel pressure guage pegs out when turnjing o n the boost pump with the engine not running and stays pebbed when pump is turned ofdf. they changed the sensor modile but did not correct the problem. It is probably the guage. 82 M20iJ
If you get a MAN1003, by the looks of it you get 14 different revisions of the POH, and the Service Manual, and the parts catalog.  After dealer markup, import duty, VAT (19.6%) and shipping, my equivalent for a Bravo came to somewhere around 200 euros, but if you're in the US I'm sure it will be a load cheaper.  Support Mooney by getting one - they're still the holder of the type certificate for your aircraft!
I guess that a MAN1011 will be more expensive, but will contain more manuals than than you need now, but if you are considering purchasing your way through the model range then it might be useful!
I've copied the USB stick to my laptop so I can read them whenever I need, and keep the stick in the aircraft so if I ever end up broken down somewhere with an A&P in the vicinity who doesn't have the manuals, then they can look up the parts and how to fit them.
Thanks Charlie,
I certainly agree with the "support them" idea although 200 EUR is much steeper than i thought :-)
Plus i currently don't own a Mooney, i just wanted to know a few models better, see which one i should choose :-)
So 200 EUR a pop...
That'll be my price as i sent a mail to Troyes Aviation to get info...
