toomany Posted March 28 Report Posted March 28 i know this had been discussed ad nauseam before but i couldnt seem to locate prior posts. regarding the bravo turbo clamps - do both the welded and riveted need to be replaced after 2 torques or is one able to be used past the 2 torque limit? i need to replace the tailpiece section of the exhaust due to heat erosion at the tailpipe bend but want to make sure about the v-clamps before i venture into it. last price i got was 2k per, which is ludicrous in my opinion. i got the entire exhaust section from plane exhaust in fl for $1200 - they did a fantastic job on the bends and welds, we'll see how it mates up. Sent from my iPhone using Tapatalk Quote
Rick Junkin Posted March 28 Report Posted March 28 @toomany Only the riveted v-band is approved for installation, P/N NH1009399-10 (Aeroquip) or 40D23255-340M (Textron-Lycoming). Here's the SB from 2004 that established the requirement. SB 283a - exhaust v-band and deflection shield.pdfFetching info... And here's the Lycoming Service Instruction that explains how the v-bands are to be installed. Assembly and Torque Procedures for V-Band Couplings.pdfFetching info... 1 Quote
LANCECASPER Posted March 28 Report Posted March 28 On 3/28/2025 at 1:34 AM, toomany said: i know this had been discussed ad nauseam before but i couldnt seem to locate prior posts. regarding the bravo turbo clamps - do both the welded and riveted need to be replaced after 2 torques or is one able to be used past the 2 torque limit? i need to replace the tailpiece section of the exhaust due to heat erosion at the tailpipe bend but want to make sure about the v-clamps before i venture into it. last price i got was 2k per, which is ludicrous in my opinion. i got the entire exhaust section from plane exhaust in fl for $1200 - they did a fantastic job on the bends and welds, we'll see how it mates up. Expand Yes, the riveted clamps still need to be replaced after two retorques, and as @Rick Junkin mentioned, that's the only clamp allowed since 2004. 1 Quote
