  • 1 month later...
Hi there,
my philosophie is to keep things short and simple.  So this is the checklist I created for our M20j.
I assume you can do a runup and after landing procedure by heart. The list covers only things that may get you into trouble.
I fly the big jets as well and I am used to short checklists.
Hope this helps you out
Cheers
Axel / Germany
NORMAL CHECKLIST D-EFRK M20J
Before Take Off
Runup......................Completed
FLT Controles...........  Checked
Fuelselector..........Fullest Tank
Trim.........................set for T/O
Flaps......................set for T/O
Cowl Flaps......................Open
Mixture..............................Rich
Prop..................................FWD
Boost Pump........................ON
Pitot Heat................as required
XPDR.................................ALT
After Takeoff
Gear....................................UP
Flaps...................................UP
Boost Pump.......................OFF
Lights .....................as required
Cruise
Cowl Flaps.....................Closed
Mixture ..........................Adjust
Approach
Altimeter...........................SET
Mixture...........................Adjust
Appr Briefing..........Completed
Fuelselector...........Fullest tank
Landing
Flaps.................................SET
Gear..............................DOWN
Mixture............................RICH
Prop............................Forward
Boostpump..........................On
Cowlflaps...............as required
After Landing
Flaps...................................Up
Boost Pump........................Off
Pitot Heat............................Off
Lights ....................as required
Mixture...................as required
XPDR..............................STBY
ABNORMAL CHECKLIST  (LDG GEAR)
Alternate gear exentsion:
- Gear lever                   down
- CB-breaker                 pull
- Lever                           unlock & pull T-handle until gear indicates down
check gear down on the annunciator panel or on the green mark in the floor
CAUTION:         Do not retract gear before stowing handle.
                           *For further Abnormals refer to AOM
